Browse Forums Bathrooms and Laundry 1 Dec 30, 2017 7:02 pm Hi everyone, Hope someone can help me with this; as you can see in the pic, one of my door trim situated near my shower was starting to rot at the bottom Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Removed the panel and now left with this... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Was thinking of redoing the silicone Inside the shower screen and putting some silcone between the tile and the wall. You can see the membrane under the tile, which stops at the trim. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ You can see in above pic that the silcone is not done Under the shower frame... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hopefully someone can advise the best way to fix without having to redo the tile and membrane. Cheers Re: Bathroom Waterproofing/Rotten wood problem 2Feb 04, 2018 6:06 am
We are having a bathroom reddone. The builders are putting down two coats of waterproofing and then screed and then another coat of waterproofing. This is what I have been… 0 1450 I have researched this topic in detail recently but for another state which has no licensing requirements at all so any handy man can waterproof any old way and not have… 1 8506 2 8673 |
