Browse Forums Bathrooms and Laundry 1 Jan 06, 2018 6:34 am I would like to build a small wall in my bathroom, in between the bathtub and vanity. This wall would be approx. 80cm wide and 150cm high - it would not reach the ceiling and would act as a kind divider. I plan to build this wall from brick and then tile it. My home is a ground floor 60s era unit of brick walls and concrete floor. Are there any special tricks for building a little wall inside a room? Or is it just laying the bricks and mortor on the ground and building up? Any advice is appreciated! Re: What do I need to know about building a small brick divi 2Jan 06, 2018 7:19 am I'm not a brickie, but having watched mine lay many of them, I think the most difficult part will be bonding/binding it to the existing surfaces, as this is what gives the wall stability. What do I need to know about building a small brick dividing 3Jan 07, 2018 3:23 pm From my partner: The wall will be fine, but the most important thing is to “tie it in” to the existing wall. Since the existing walls are brick, just drill into it every 4 or 5 courses and put in a control joint pin (or the more the merrier ie you can put in one every 3 courses if you like or 2 pins at a time). Owner Builders in boot-shaped Yorke Peninsula : viewtopic.php?f=38&t=80264& Re: What do I need to know about building a small brick divi 4Jan 23, 2018 8:41 pm You can also consider something more simple and straightforward such as buying out some steel studs and channels at Bunnings and then screwing them to your floors and ceiling and then screwing waterproof plasterboard and tiling on top. Why does it necessarily have to be a brick wall? Do I need to concern about this pattern of crack? Is this crack showing some signs of bigger problems? Thanks for any suggestions! 1 1914 Hi all, We are looking to build a new two storey house in western Sydney. Can anyone recommend a smallish builder to go with? We are trying to stay away from the big… 0 12145 consider putting in wall WC instead of robe in the same bedroom, then it might be doable to hook up to the existing piping. 4 6629 |
