Browse Forums Bathrooms and Laundry 1 Dec 09, 2017 1:24 pm hi there, I made the mistake of putting in a very narrow bath. with the shower screen on the inside of the lip, there is barely enough space on either side of your shoulders – bad mistake. I don't want to rip out the bath, but would like to move the screen out. Here is my idea, but am unsure of how to fill the area between the lip and the glass. There needs to be a channel so the water off the screen goes back into the bath and does not puddle between the bath lip and the glass. https://photos.app.goo.gl/VUOwc9GvzkH3MPZI2 here's a bigger pic of the bathroom, for context https://photos.app.goo.gl/FbO5PPCZ1kzNxF7r1 Ideas 1. a piece of timber (waterproofed) that the glass would sit on, timber molded so there is an angle for the water to drain back into the bath. pretty cost effective. 2. piece of stone – similar to the timber, prolly alot more expensive 3. a little tiled hob on top of the existing hop. might look a little odd as the other tiles are 300x600 around the bathroom any other suggestions or comments? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ move the screen out to give more shoulder and elbow room, it's tight!Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Your shower screen has failed in the way it is designed to fail with tempered glass. You could replace it with laminated safety glass but make sure it has AS standards logo on it 1 11171 Hello everyone, I have a question regarding moving a chandelier after it has been mounted. The chandelier in question is quite large, measuring 4 meters… 0 72337 You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of… 1 7071 |
