Browse Forums Bathrooms and Laundry Re: Fixing dripping Dorf tap 2Dec 14, 2017 1:31 pm Bill1000 I'm trying to fix a dripping Dorf tap but to do so I need to remove the cone shaped fitting that sits on the washbowl. Its stuck! Any suggestions on how to remove it without damaging the fitting? Without a picture I can’t say. But hazarding a guess you need a strap wrench.... https://www.bunnings.com.au/haron-160mm ... h_p4900119 Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9563 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4857 DIY, Home Maintenance & Repair This is a very challenging situation, made much harder by not being on site. Firstly, I think that I originally… 10 8965 |
