Browse Forums Bathrooms and Laundry 1 Oct 29, 2017 12:21 pm Is it normal to tile the wall straight to a door jam without architraves? we either have a choice to have a really narrow door with architraves or widen the door and have no architraves. What will look the best? I have attached a photo of our door. The left hand side we have removed and are considering whether to remove the right hand side for a bigger door. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Bathroom door - wall tiling to door jam 2Oct 29, 2017 1:51 pm Can't really tell from that shot, is that the jam or the frame, I'm thinking frame seeing there's frame above? Short answer there's no right way to do anything like this, there's better finishes than others, you do what works and looks best for your bathroom as long as it's to code. Re: Bathroom door - wall tiling to door jam 3Oct 29, 2017 1:55 pm That is the door frame that we have half removed as the bath won’t fit in. Once the floor is tiles we will bring the bath in and re frame. Then we would need to add the door jam. The smaller door option means the door is 680 - is that to code? Or does the door have to be a certain width? Screed is installed before or after, what was not up to code? You have 4x images, door frame, The work is poorly applied rough, with no care for how it should be done, if… 5 2900 I was in a similar situation needing to attach hangers to a hollow bathroom door. I just bought the stick on type with a larger surface area base and used good double… 2 5539 DIY, Home Maintenance & Repair Thanks Chippy . Did also see a YouTube video before. Removed them . Thanks again for the advice. 2 14064 |
