Browse Forums Bathrooms and Laundry 1 Oct 13, 2017 10:44 pm After some opinions! We are finalizing our new house plans, all but finished before we sign the PCC. Something husband and I can't reach a decision on is whether to include a sink in the seperate toilet next to the main bathroom. Builder wants almost $1,400 extra for this and it sounds like one of those basic tiny rectangle ones so in all likelihood we'll change it and it will be more. Husband thinks not worth the money. Also under consideration is whether having a seperate loo is "old fashioned" and as we will have three toilets (ensuite and a seperate one in the laundry) we should just enclose within the main bathroom to have a larger bathroom and do away with the whole sink issue. Our family situation is two of us, a toddler and one on the way 😃 Current bathroom layout in the pick (with sink we've said to take out...) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Sink in seperate toilet or combine with main bathroom? 3Oct 14, 2017 6:26 pm Definitely drop those tiny sinks. Pointless and looks cheap. Re: Sink in seperate toilet or combine with main bathroom? 4Oct 14, 2017 7:42 pm If you have a separate toilet in the laundry, get rid of the powder room and just incorporate it into the bathroom itself Re: Sink in seperate toilet or combine with main bathroom? 5Oct 14, 2017 9:23 pm I prefer a separate toilet but would drop the tiny sink <!-- l --><a class="postlink-local" href="https://forum.homeone.com.au/viewtopic.php?t=62083">viewtopic.php?t=62083</a><!-- l --> Re: Sink in seperate toilet or combine with main bathroom? 8Oct 16, 2017 12:45 pm I prefer a separate toilet. I like the idea of the basin but for $1400, not so much! Toilets in bathrooms are ok while kids are young. Ours have reached that delightful age where they want privacy and shut each other out. I can't wait to move and have a separate toilet again! Even with another toilet off the laundry, kids aren't going to think to go use the separate toilet just in case their sibling wants to use the bathroom! Re: Sink in seperate toilet or combine with main bathroom? 9Oct 16, 2017 2:29 pm bank I prefer a separate toilet. I like the idea of the basin but for $1400, not so much! Toilets in bathrooms are ok while kids are young. Ours have reached that delightful age where they want privacy and shut each other out. I can't wait to move and have a separate toilet again! Even with another toilet off the laundry, kids aren't going to think to go use the separate toilet just in case their sibling wants to use the bathroom! As the parent of kids who have reached this age, this. Separate toilet is a must for family harmony! I personally am a great fan of separate sinks (our new house has two powder rooms with sinks in both), but ours are costing us less than half of yours (and that's not going with the cheapest option, and including builders' margin as well)! It depends on how bothered you are with the fact that people won't be able to wash their hands before using the door handle(s) to leave the toilet and get to the bathroom. Re: Sink in seperate toilet or combine with main bathroom? 10Oct 17, 2017 7:40 pm We have three kids and I think in years to come I’m going to be thankful I put a sink with my toilet. Building our first custom dream home. https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: Sink in seperate toilet or combine with main bathroom? 11Oct 18, 2017 1:20 am Well, considering there is some reason why you make your toilet separate with the separate entrance, it definitely makes sense to put in a small sink there. Otherwise, someone who have just used the toilet, will be required to open at least two doors with their dirty hands in order to wash them up. Not very hygienic, if you ask me. And imagine if someone is having a bath or shower at the same time (and, therefore, locked the door). Small sink and mixer would cost something like $150 ($300 installed) and plumbing should not be huge problem/cost differentiator considering that they already do cold water plumbing for your WC and hot and cold water plumbing to your bathroom sink right next to it. Generally, if you can't negotiate common sense with the builder, just ask them to put in a plumbing provision and then buy sink and mixer and install using your own plumber later. Re: Sink in seperate toilet or combine with main bathroom? 13Oct 19, 2017 6:44 pm arcadelt Building a Madison 45 with Porter Davis Madison 45 Blog (Send me a PM with your email address to be added) Re: Sink in seperate toilet or combine with main bathroom? 14Oct 22, 2017 1:44 pm fademan Definitely include a separate sink. If anyone is in the shower and the door is locked, you're in trouble. $1200 isn't that much for a sink. Does it include splash back tiles and a mirror? No it doesn't include that, would be $1,400 and then those are extra. We've gone a half-way house - got provision plumbed in for a sink (water/waste) but will install one ourselves later. Re: Sink in seperate toilet or combine with main bathroom? 15Oct 25, 2017 11:00 am Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hello there. We were facing the same issue with our bathroom but changed to this configuration which will hopefullly work a lot better (house hasn't been completed yet). This provides us with a larger shower and removes the problem of the bathroom door potentially clashing with the shower door. Only issue is that anyone using the vanity loses any privacy unless you want to add an additional door. we found it fitted in almost perfectly to the original plan but did cost (ironically) around the $1,400 to change but we did decide on this one quite late in the process. Hope this helps! Re: Sink in seperate toilet or combine with main bathroom? 16Oct 25, 2017 12:52 pm Providing it's not the only bathroom in the house, I prefer the toilet in the bathroom. I like the 'one stop' approach. If you're going to separate the toilet, the sink should be in the toilet, otherwise as mentioned to by a PP it's unhygienic having to open and close doors without washing hands. Also if your separate toilet is so that someone can use the toilet while someone else is in bathroom, not being able to then use the sink in the bathroom is a negative. Re: Sink in seperate toilet or combine with main bathroom? 17Feb 03, 2019 4:06 pm nicolac34 fademan Definitely include a separate sink. If anyone is in the shower and the door is locked, you're in trouble. $1200 isn't that much for a sink. Does it include splash back tiles and a mirror? No it doesn't include that, would be $1,400 and then those are extra. We've gone a half-way house - got provision plumbed in for a sink (water/waste) but will install one ourselves later. Any photos of your finished toilet with hand basin? I am having the same dilemma and there are pros and cons to installing a hand basin in the separate toilet, or removing the dividing wall and incorporating the toilet within the main bathroom. Re: Sink in seperate toilet or combine with main bathroom? 18Feb 03, 2019 4:43 pm Bebbsy nicolac34 fademan Definitely include a separate sink. If anyone is in the shower and the door is locked, you're in trouble. $1200 isn't that much for a sink. Does it include splash back tiles and a mirror? No it doesn't include that, would be $1,400 and then those are extra. We've gone a half-way house - got provision plumbed in for a sink (water/waste) but will install one ourselves later. Any photos of your finished toilet with hand basin? I am having the same dilemma and there are pros and cons to installing a hand basin in the separate toilet, or removing the dividing wall and incorporating the toilet within the main bathroom. Hi We didn’t go through the builder to install our sink as we didn’t like their options - we wanted something simple and it was too expensive. We got the pipework put in (and the toilet wider than normal to accommodate) and bought the sink/tap etc ourselves and had a plumber install. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Sink in seperate toilet or combine with main bathroom? 20Feb 03, 2019 8:09 pm i think it should be compulsory to have a sink in toilet room walking through the house with dirty hands touching door handles light switches along the way and my wife always has something soaking in the laundry sink The warning is on the sticker on the door too. Second the aluminium powdercoat 6 18703 2 6331 Until you find the cause of the flooding you need to take action to mitigate potential damage to your home. Get automatic float pump and dig a pit then connect to power… 2 4917 |
