Browse Forums Bathrooms and Laundry 1 Oct 06, 2017 11:46 am Hi all, Long story short, my fathers newly renovated bathroom (ground level) has had an unknown amount of concrete poured down the main floor drain. Are there any suggestion of how best to go about fixing this problem without ripping up the floor and starting again? He has mechanically chipped away what he can get to, but the pipe then bends 90deg I believe and getting further is proving near impossible. Are there any solvents that will dissolve the concrete but leave the pipe undamaged? Or tools that will mechanically break the concrete around the corner? Any advice much appreciated, thanks. Re: Removing concrete from drain 2Oct 06, 2017 3:31 pm I have successfully deblocked sewer pipes full of concrete with concentrated hydrochloric acid. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Removing concrete from drain 4Oct 06, 2017 5:02 pm bunnings, straight out of the bottle Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8489 Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4546 Agreed. I just found out today the certifier has not given the final sign off. 2 4094 |
