Browse Forums Bathrooms and Laundry 1 Jul 25, 2017 10:18 am Hello, I've built a new home with Clarendon and have found the falls in bathroom floor tiling inadequate to drain water, both in shower recess and bathroom floor. Upon inspection, Clarendon's tiling contractor have agreed to repair the floor, by removing the floor tiles to re-lay. The tiler has said they can remove only the floor tiles and mortar bed without damaging wall tiles or the waterproofing membrane. I am concerned that the waterproofing membrane will be compromised when removing the floor tiling, and that spot patch repairs to the membrane is not appropriate. Could somebody please offer advice on my issue? I feel that the waterproofing would need to be re-done completely, meaning removal of wall tiles also. Thank you Re: Bathroom Floor Tile Replacement and Waterproofing 2Dec 27, 2017 5:43 pm Can someone provide some insight into this issue? I have a situation where the tilers have laid wrong floor tiles and have advised that they will rectify this. So will this require them to redo the waterproofing? should I insist and make sure that the water-proofing is re-done? Re: Bathroom Floor Tile Replacement and Waterproofing 3Apr 21, 2018 5:56 pm We are having the same issue with the shower base of one of our showers. Our independent inspector picked up that the tiling was uneven. They agreed to get the tiler back and fix it. We wanted photographic evidence that the membrane wasn't ruptured. We didn't get it! Can you believe it, the tiler has retiled them uneven again. They now have to be pulled up for a second time so we are saying surely the water proofing has to be re done this time. It is honestly so frustrating. We were supposed to be in our house in December. Re: Bathroom Floor Tile Replacement and Waterproofing 4Apr 22, 2018 8:45 pm lolly72 We are having the same issue with the shower base of one of our showers. Our independent inspector picked up that the tiling was uneven. They agreed to get the tiler back and fix it. We wanted photographic evidence that the membrane wasn't ruptured. We didn't get it! Can you believe it, the tiler has retiled them uneven again. They now have to be pulled up for a second time so we are saying surely the water proofing has to be re done this time. It is honestly so frustrating. We were supposed to be in our house in December. Hey, I would suggest to request the waterproofing certificate, see what the waterproofer thinks - it may void the waterproofers warranty. I spoke to a waterproofer when I was pursuing my repairs, and it was arranged that they would provide an independent inspection after tiles were removed but most likely be re-sealing because you possibly won’t see the damaged membrane. In the end, Clarendon Homes performed no rectification at my home. After their contractor refused to complete the repair, They went down the path of deeming the defect not major, since I was outside the three years minor defect period. After all the stress of a tribunal and having unanswered calls I gave up. Research your defects periods, understand what certificates the builder should be providing and get an independent building inspection during your minor defect period We are having a bathroom reddone. The builders are putting down two coats of waterproofing and then screed and then another coat of waterproofing. This is what I have been… 0 859 Possibly both depending on the sizing. Idea of working from the centre is that you dont have a 20mm thin tile at one end and a 400mm at the other end. A quick search on… 3 8417 Hey There. No problems re jumping in. My original question was "should I have waterproofed" the concrete slab before putting batons down. We have been told we should… 7 4328 |
