Browse Forums Bathrooms and Laundry 1 Jul 20, 2017 6:07 pm G'day all, I have a freestanding bath to install and something has me worried and confused. Its a concrete floor and I'm wondering how I put the waste pipe in the exact right spot it needs to be to line up with the bath tub plug and waste? If set the pipe in the wrong spot by even 30 mm it will obviously cause a few problems. Also, how do I screw in the plug and waste attached to the pipe when the pipe is sticking out of the floor? Do I install a larger diameter PVC pipe and have a short piece attached to the bath plug and waste and drop that into the floor would anybody know? I'm confused as to how I do this with a freestanding as I know I would have access and a little room to play with if I were installing an older type bath to do this before I boxed it in and tiled it. Any advice or know how much appreciated. Thanks Geoff Re: Lining up floor waste 2Aug 11, 2017 7:54 pm Why don't you contact a very good contractor. I guess they give you the best answer than you get from any source in Internet Hi, I am sheeting the inside of a 5.7 x 8m shed with gyprock. Unfortunately the shed wasn't designed for internal cladding but I have been framing it up as strongly as… 0 3426 Hi, I'm new to this forum so I hope I'm doing this post correctly. Please advise if it's not. I've just bought my place. The inground pool has a marble lining that has… 0 13663 There are a lot of private inspectors should have stayed working as tradies!! Firstly, you paid for a professional opinion of the works, if he has picked up on an item he… 1 2042 |
