Browse Forums Bathrooms and Laundry 1 Jul 03, 2017 8:14 pm Hey guys Just playing around with plans for the master ensuite and have a clear 2.6m wall. Would love to do an open shower on both ends such as attached. Any recommendations on minimum width for the piece of glass in order to contain water sufficiently? I was thinking 1.6m with 50cm gap on either end? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Follow our Arden Toulouse build at http://ardentoulouse.blogspot.com.au Re: Open shower on both sides 2Jul 03, 2017 9:42 pm You might want to consider the convection created by the heat rising and the draft created by open sides. It makes for a pretty unpleasant shower experience, which I guess is great if you want to limit shower times. Re: Open shower on both sides 3Jul 03, 2017 9:45 pm arcadelt You might want to consider the convection created by the heat rising and the draft created by open sides. It makes for a pretty unpleasant shower experience, which I guess is great if you want to limit shower times. I have to say I never used a shower like that before. Just like how it looks. Is it really that bad? Follow our Arden Toulouse build at http://ardentoulouse.blogspot.com.au Re: Open shower on both sides 4Jul 03, 2017 9:46 pm arcadelt You might want to consider the convection created by the heat rising and the draft created by open sides. It makes for a pretty unpleasant shower experience, which I guess is great if you want to limit shower times. What is your opinion on a shower with just one open end? Follow our Arden Toulouse build at http://ardentoulouse.blogspot.com.au Re: Open shower on both sides 5Jul 03, 2017 9:55 pm I guess it depends where you live? North of Broome or Townsville would be OK I guess, but in the south in winter, maybe not. Have a shower with the door open and judge for yourself, then consider it being open on both sides. Re: Open shower on both sides 6Jul 03, 2017 10:02 pm arcadelt I guess it depends where you live? North of Broome or Townsville would be OK I guess, but in the south in winter, maybe not. Have a shower with the door open and judge for yourself, then consider it being open on both sides. Ive tried that though only one ive been able to test it in was a 1m one. The shower would be against 3m of wall. Perhaps one open end with 2.2m of glass would be sufficient to not feel cold Follow our Arden Toulouse build at http://ardentoulouse.blogspot.com.au Re: Open shower on both sides 7Jul 05, 2017 10:14 am geminithinker Hey guys Just playing around with plans for the master ensuite and have a clear 2.6m wall. Would love to do an open shower on both ends such as attached. Any recommendations on minimum width for the piece of glass in order to contain water sufficiently? I was thinking 1.6m with 50cm gap on either end? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hey Geminithinker I think it's a great idea! Don't worry you won't feel cold with that design, I have an open shower / Bath wet area and it's great, we live in Sydney. see attached pic - Good luck with the Renovation! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Regards James Mason www.renovationjunkies.com.au Re: Open shower on both sides 8Jul 11, 2017 2:07 pm I worked for a shower base company a while ago, 1300mm splash furtherest splash from the shower head. This is based on a 1.8m person. Personally, I think this looks great having it open both ends. I have an open shower at the moment... in Melbourne, I've never noticed the cold. Hey everyone Not for me or anyone I know, just generally interested. For a single allotment house, are you allowed to take the fence on both sides of your house and… 0 20888 thanks. the above one is white Mat tiles and have gripness so going for this Mat tiles for both indoor and outdoor. Beaumont told it can be used in both indoor and… 2 1662 Cupcake.girl This really depends on your local council. Each one has different definitions and ways to calculate contributions. This is called a contribution… 1 3580 |
