Browse Forums Bathrooms and Laundry 1 Aug 21, 2008 8:43 pm Hi All!
We are owner building and have finally moved in! !!! BUT we have a rinnai infinity and the temp is low for safety reasons (not by our choice) Is there anyway to override the auto temp as we have NO water pressure! Due to the temp, we only need a small amount of cold water. So if the water was hotter, then wecould add more cold water hence more pressure! It takes AGES to fill a bath, and our huge shower heads are a let down So can anyone offer any advice?? Re: Temp control for Infinity Hot Water 2Aug 24, 2008 12:37 pm matamber,
Firstly the disclaimer - I'm no expert and haven't done this before. Try at your own risk. If you unscrew the front cover, there should be an information pamplet in a plastic pocket at the back of the cover. The info shows you how you can increase the temperature by changing the setting of some switches. Chris 0 15692 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14048 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20230 |
