Browse Forums Bathrooms and Laundry 1 Jun 10, 2017 9:03 am Hi, Apparently wall mounted tapware is more expensive than basin mounted equivalent. Not sure why. But I'm thinking about practicality. Wall mounted should be easier to clean (less dripping down the tap stem) but are they more difficult to service (replace washers etc) Appreciate all advice. Thanks GLO Re: Taps wall mount or basin mounted? 2Jun 10, 2017 9:11 am Given modern finishes, I would have thought it was pretty easy to clean taps installed either way. The bigger issue for me is maintenance of both the taps and plumbing, and given that bench mounted taps leave the plumbing accessible, this would be easier. That said, good quality taps should last ten years. So with wall mounted taps you would only need to open the wall every ten years or so. Taps wall mount or basin mounted? 3Jun 10, 2017 10:36 am My partner's concern who is a tiler is If something goes wrong that you have to open the wall, then you have to replace tiles as well. But no different than the shower/bath tap really. Just more of personal preference I think. We got wall mounted for ensuite in the end. Owner Builders in boot-shaped Yorke Peninsula : viewtopic.php?f=38&t=80264& Re: Taps wall mount or basin mounted? 4Jun 15, 2017 10:59 pm I have wall mount taps and they are a disaster. There is constantly a pool of water on the bench below them because you turn them off with wet hands (doesn't help if you have little kids too). I have a face washer sitting there permanently so that the water doesn't pool over onto the floor. Never again..... Re: Taps wall mount or basin mounted? 5Jun 21, 2017 5:31 am ankledeep I have wall mount taps and they are a disaster. There is constantly a pool of water on the bench below them because you turn them off with wet hands (doesn't help if you have little kids too). I have a face washer sitting there permanently so that the water doesn't pool over onto the floor. Never again..... Thanks for sharing your experience Hello everyone, I have a question regarding moving a chandelier after it has been mounted. The chandelier in question is quite large, measuring 4 meters… 0 72334 If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8310 Bathroom renovation will likely include a back-to-corner bath and we’re considering a freestanding tap with hand-held shower such as the picture included. My hesitation… 0 24692 |
