Browse Forums Bathrooms and Laundry Re: Bathroom Tile size 2Nov 30, 2006 1:54 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Bathroom Tile size 4Dec 01, 2006 7:18 am There you go NeilD, this photo shows you the full benefits of a larger tile.
Note the tidiness of the look, less joins and grout! LESS CLEANING! The 600 x 300 are a rectangle where these tiles are square, for a small size bathroom I would do the rectangles, less wastage on tiles. Nice bathroom alto, did you do the tiling yourself? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Bathroom Tile size 5Dec 01, 2006 8:27 am MMM..now it's even worse going out today to scan some tile displays. Both those ideas are great..I like the idea of less grouting vey much I HATE grouting. If all you can see are obstacles, you have lost sight of the goals Re: Bathroom Tile size 6Dec 02, 2006 1:32 pm Michelle Nice bathroom alto, did you do the tiling yourself? Thanks Michelle. I am only responsible for choosing the tiles - the builder has done the rest. I will post more pics once we're in and the place is clean. Re: Bathroom Tile size 7Dec 09, 2006 1:09 pm Michelle There you go NeilD, this photo shows you the full benefits of a larger tile. Note the tidiness of the look, less joins and grout! LESS CLEANING! The 600 x 300 are a rectangle where these tiles are square, for a small size bathroom I would do the rectangles, less wastage on tiles. Nice bathroom alto, did you do the tiling yourself? Eureka. Found one that's perfect. It's 400 by 250, white, with a very fine texture, and not really glossy, in fact almost matt. Not quite the size you suggested Michelle, but as soon as I saw it I knew it was right. I was a bit worried about there being a problem in cleaning them so I brought a sample home, rubbed some dirt into it and gave it a wipe. Voila!! the texture isn't enough to hold dirt...came up just fine. If all you can see are obstacles, you have lost sight of the goals Re: Bathroom Tile size 8Dec 09, 2006 4:22 pm Excellent Neil, good size to lay as well, not to heavy.
Glade you found something! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Possibly both depending on the sizing. Idea of working from the centre is that you dont have a 20mm thin tile at one end and a 400mm at the other end. A quick search on… 3 8417 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7497 All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers. 1 3664 |
