Browse Forums Bathrooms and Laundry 1 May 08, 2017 8:57 pm Hello again, We have a skinny ensuite where our double vanity at 1600mm (small) has 2 undermount sinks which will leave very little bench space. Our builder has designed tiles on each wall beside the vanity which is practical for splashing I guess. My question is from a looks perspective it wrecks the look we are after (straight lines) - Do we need to do this or would plain wall beside the vanity be fine (its for adults only).? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 1600mm double vanity between 2 walls - need advice.. 2May 09, 2017 1:01 pm Personally, with the edge of the basins so close to the walls, I would put the tiles there; but if you are happy to clean the walls frequently and risk staining (which can be easily fixed by repainting) then do what you want. Transform your bathroom into a sanctuary of calm and sophistication with Hera Bathware's Bathroom Vanity Collection. A standout… 0 12281 Thank you so much for the effort. We will use it to talk with builder. We also had idea of building duplex instead and seeking suggest ions. viewtopic.php?f=31&t=106744 11 13842 Levelling compound Ardit is the best but buy a bag of sand and make sand dam to protect your wood floor 2 15253 |
