Browse Forums Bathrooms and Laundry 1 May 07, 2017 8:12 am I don't like panels, either;) I want something like the inside of my bathtub on the walls, like paint. Can anyone recommend something to paint the walls with something that is equally waterproof as tiles? How about epoxy or something similar coating? I want to use it in all of the bathroom and in the shower zone. I can't imagine anything more durable than something like a plastic layer coating on the walls? Re: I hate tiles 2May 07, 2017 8:18 am I must say I don't quite understand your opposition to tiles, but it is your home so your choice. Tiles themselves are not waterproof. It's the waterproof membrane behind them that does that. You could perhaps look at an acrylic solid surface like Staron or Hi-Macs, but it ain't cheap. Perhaps a vinyl product (typically used in commercial applications such as ensuite walls in aged care and hospitals). Or I suppose you could go for an applied finish like a render or plaster. If you try and paint over the waterproofing membrane it will look very poor as you will see the membrane texture. Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: I hate tiles 3Jul 11, 2017 2:22 pm I was going to suggest the same thing as 60'smodernist - solid surface like mentioned could be a good option, even painted glass splash back. You can get solid surface in 6mm, which is slightly cheaper then 12mm (standard thickness) solid surface. Make sure you get acrylic based solid surface that is UV stable. The acrylic doesn't mean that plastic sheet, solid surface still feels like stone, but the acrylic based means it's UV stable and won't discolour. Brands like Hi-Mac, Corian etc, are UV stable. Always check! Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the… 3 7776 Our house was completed 8 years ago. Builder did not leave any spare roof tiles behind. Just found out that one tile is cracked. Wanted to replace the tile but most… 0 2781 1 15753 |
