Browse Forums Bathrooms and Laundry 1 Apr 17, 2017 8:10 pm The building is on the go and the bathroom fittings have been chosen (mostly) and so the question is - what height is best for the shower rose? We look like getting the large roses 200-300mm diam., which I have never showered under, and they will be on vertical droppers from the 2.7m ceilings. I'm thinking 500mm-600mm droppers, but I'm happy to take advise from those with experience. I'm 1.75m tall and the wife a bit shorter. Cheers. Pat Re: What height shower rose? 2Apr 22, 2017 3:22 pm Hey Pat Around 2mtrs from the floor is a good height, so a bigger dropper closer the the 600mm would be best in my opinion. Regards James Mason www.renovationjunkies.com.au Re: What height shower rose? 4May 20, 2017 10:26 am If you increase the height of the shower head you might want to see that the screen height and tiling is also raised. On our standard plans the wall mounted shower rose is 1900mm high, screen is 2000mm high and tiling to 2100mm high. We will raise these a little as our ceilings will be higher than the standard 2440mm (so it looks proportional). Second Time 'Round Re: What height shower rose? 5Jun 03, 2017 8:34 am Our Build123 Hey Pat Around 2mtrs from the floor is a good height, so a bigger dropper closer the the 600mm would be best in my opinion. Regards James Mason http://www.renovationjunkies.com.au James you are the best Anyone built this plan before? Would be great to chat about it. Thank you. 0 26697 Correct. External the eaves will sit on top of the window frames, internally there will be 3 courses to the ceiling. Those details are from our house. We went with 28c… 5 9424 Slab needed a rebate. Better planning during design stage. Nothing can be done now without spending big $$$. 2 13471 |
