Browse Forums Bathrooms and Laundry 1 Apr 17, 2017 9:10 pm The building is on the go and the bathroom fittings have been chosen (mostly) and so the question is - what height is best for the shower rose? We look like getting the large roses 200-300mm diam., which I have never showered under, and they will be on vertical droppers from the 2.7m ceilings. I'm thinking 500mm-600mm droppers, but I'm happy to take advise from those with experience. I'm 1.75m tall and the wife a bit shorter. Cheers. Pat Re: What height shower rose? 2Apr 22, 2017 4:22 pm Hey Pat Around 2mtrs from the floor is a good height, so a bigger dropper closer the the 600mm would be best in my opinion. Regards James Mason www.renovationjunkies.com.au Re: What height shower rose? 4May 20, 2017 11:26 am If you increase the height of the shower head you might want to see that the screen height and tiling is also raised. On our standard plans the wall mounted shower rose is 1900mm high, screen is 2000mm high and tiling to 2100mm high. We will raise these a little as our ceilings will be higher than the standard 2440mm (so it looks proportional). Second Time 'Round Re: What height shower rose? 5Jun 03, 2017 9:34 am ![]() Hey Pat Around 2mtrs from the floor is a good height, so a bigger dropper closer the the 600mm would be best in my opinion. Regards James Mason http://www.renovationjunkies.com.au James you are the best Hi all, Leaking shower head and unsure how to safely open and replace the washer etc due to the unique type of shower taps. I'm a bit worried about forcing off the tap… 0 2113 G'day, Never had to reno a shower before and I'm really not sure how to go about it. What I've got is an early 90's era shower where the shower pan is recessed into the… 0 1611 Definitely do it if you can afford, that's one of the upgrades you can't change later on.I selected cheaper tiles and stone to make up for the cost of the height upgrades. 3 1281 |
