Browse Forums Bathrooms and Laundry Re: Laundry sink in the kitchen - In Victoria 2Apr 16, 2017 8:10 pm Oh I should mention that I will have a double kitchen sink that will be near the washing machine. Re: Laundry sink in the kitchen - In Victoria 3Apr 18, 2017 11:21 am No you don't. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Laundry sink in the kitchen - In Victoria 4Apr 22, 2017 1:33 pm ausdesign No you don't. I have been checking the minimum requirements for Occupancy Permit in Victoria and came across these requirements in the NCC. 3.8.3.2 Required facilities a) A Class 1 building must be provided with— (i) a kitchen sink and facilities for the preparation and cooking of food; and (ii) a bath or shower; and (iii) clothes washing facilities, comprising at least one washtub and space in the same room for a washing machine; and (iv) a closet pan and washbasin. Explanatory information: A kitchen sink or washbasin must not be counted as a laundry washtub. However, a laundry washtub is considered to provide the necessary means to dispose of waste water as required by P2.4.3. Why does this requirement not apply in this particular case ? Re: Laundry sink in the kitchen - In Victoria 5Apr 26, 2017 6:14 pm I don't think that having a laundry sink is a prerequisite in houses unless you absolutely want to have one for yourself. I should think that for practicality's sake that I wouldn't do my washing in the kitchen unless I have no other options though. I can't imagine having all those clean clothes around oily and potentially dirty kitchen counter top surfaces. But that's just me. What seems to be the officer's problem? Re: Laundry sink in the kitchen - In Victoria 6Jun 10, 2017 9:45 am Its the waste water bit. How would the washer do this in the kitchen ? Re: Laundry sink in the kitchen - In Victoria 7Jun 10, 2017 10:10 am Saint Mike Its the waste water bit. How would the washer do this in the kitchen ? Both waste pipes would connect to the sewer. Kitchens are becoming more and more multi-functional. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 3in1 Supadiverta. Rainwater Harvesting Best Practice using siphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost, siphonic, eaves gutter overflow solution. Re: Laundry sink in the kitchen - In Victoria 8Jun 11, 2017 3:43 pm Wow - now that would be useful - you could make a coffee while on the phone while ... Re: Laundry sink in the kitchen - In Victoria 9Jun 11, 2017 7:55 pm I don't think it is necessary either. I have definitely seen plans for granny flats and apartments having WM in kitchen without the a laundry sink which some of those only have a single kitchen sink. Re: Laundry sink in the kitchen - In Victoria 10Jun 16, 2017 9:15 pm This is common in England, very rare in Australia, we're just not use to it, might work OK with a single or a couple, but would imagine it getting very difficult with bigger families. Re: Laundry sink in the kitchen - In Victoria 14May 20, 2024 1:33 am Nah, you don't necessarily need a laundry sink if your washing machine is in the kitchen. It's more about having access to a drain for the machine. Some people just use a hose hooked up to the kitchen sink or a nearby drain. Re: Laundry sink in the kitchen - In Victoria 15May 20, 2024 7:52 am jagberg Nah, you don't necessarily need a laundry sink if your washing machine is in the kitchen. It's more about having access to a drain for the machine. Some people just use a hose hooked up to the kitchen sink or a nearby drain. This is incorrect Re: Laundry sink in the kitchen - In Victoria 16Jul 08, 2024 6:13 am BarbaraHenry45 No, you don't need a laundry sink if your washing machine is in the kitchen. You can just connect the washer to the kitchen sink plumbing. Done this before, and it works fine This isn’t code complaint. Check your standards. Hi, I´m in the middle of planning a renovation in a unit, level 18. At the moment the kitchen sink is directly connected to one vertical soil stack, and it´s the only… 0 6600 Thanks and agreed, I was initially very suspicious that the tenant had caused this. The only thing that's throwing me is I'm getting similar cracking in the bathroom and… 4 6790 Old Home Restoration / Renovation I cannot find a review for the Reblocker I am getting a quote from. Am I doing something wrong, or are numbers of reblockers who hold VBA registration not reviewed on your… 0 10560 |
