Browse Forums Bathrooms and Laundry 1 Feb 24, 2017 2:16 pm My bath sprout is leaking, trying to fix it by replacing tap valve, washer or O-ring, not sure which one. But, I cannot get the handle off. I have already unscrew most of things, but the spindle cannot be unscrewed, no matter how hard I pushed. Seems it is welded into pipe. I need help. How can I get it off? [img=400x300]https://valpa.github.io/pics/IMG_20170224_144941.jpg[/img] [img=400x250]https://valpa.github.io/pics/IMG_20170224_145035.jpg[/img] Re: Bath handle cannot be taken off to replace tap valve 3Feb 28, 2017 1:25 pm No one welds them in, no point. You are doing it the right way, just might have t use a h/duty version box wrench. Give it a short, hard whack. If worse comes to worse, you 'll just have to break the tiles and get in behind it. Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9074 Good luck with it. I don't know what the cost of a nice bidet seat with a 25mm air gap will be but you are obviously deducting the cost of a RPZ valve and its… 9 6985 First time building 2 storey home, is under construction (in Framing stage) in NSW. I have 3 toilets and need bidet spray in… 0 16853 |
