Browse Forums Bathrooms and Laundry 1 Oct 21, 2016 11:46 pm Our tiler is trying to tell us that for a 600x300 floor tile, is he does a 3mm grout line, he won't need to cut into tiles to create the diamond pattern to get fall to the drain. However if he does a 1.5mm grout line then he will need to do the cuts. This is in the shower (hobless with strip grate) as well as the Bermuda waste to the middle of the room. I knew tile size impacted difficult of creating fall but didn't think 1.5mm less grout lines would impact it. Wondering if he just doesn't want to do harder work (if it even is harder) C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Thank you Splashers. Tomorrow I might check if I can get a few packs of 300x300 in the same tile finish. It may be good to use these could in the shower recesses. I'm not… 4 4671 I've got a challenge here. Background is the builder has cut too deep for the slab and the slab is now below the very substantial retaining wall. It's failed occupancy… 0 18375 Thanks splashers, that makes sense. The waterproofing guy used this Davco product, I will raise the issue with builder and hopefully get resolved with him - if not… 2 12883 |
