Browse Forums Bathrooms and Laundry 1 Oct 20, 2016 3:45 pm I have a spout that I've taken off for a job but the job's delayed and I need to put it back on for a couple of weeks. Obviously, I don't want to get a plumber in to screw in a spout (due to call out fees) but I'm having trouble getting it tight enough. It is mounted on the bench. When I slot it through, I can find the 'bolt' underneath and can screw it on by hand. But I can't get it tight enough by hand so that it doesn't leak. I can't use a standard shifter as there are horizontal pipes in the way, running just below the 'bolt'. I need something like a long-nosed shifter but I don't know if these exist. Any ideas? Re: Long-nosed shifter, or alternative 2Oct 22, 2016 4:41 pm https://www.bunnings.com.au/haron-mixer ... t_p6110476 Grab one of these if it's a mixer Or one of these for other nuts https://www.bunnings.com.au/haron-240-4 ... h_p4900070 Might cheaper to changer your idea of what makes a home, have you considered building a porch? 2 51774 Congratulations! Nice to put that to bed before christmas, now you can relax 3 7119 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8506 |
