Browse Forums Bathrooms and Laundry Re: Shower base cheap fixes 3Jun 24, 2016 10:48 pm Tell me what type of shower base it is an i might be able to lead you in right direction.for all to say get a plumber he will set your rite.well i am a plumber and as you all know to remove an install a new shower base is not a cheap affair. For a cheap repair check out epoxies or if you dont care about colour then look up liquid rubber online.works well for a cheap fix Re: Shower base cheap fixes 5Jun 25, 2016 8:33 am You most definitely don't need a plumber if you are ripping this out in a couple of years! All you need is a paint on sealant straight out of a can. Bunnings have some clear sealants but you need to find one that will stick to acrylic or fibreglass. Give the shower enclosure a good scrub, rinse and let dry for a few days then apply the sealant. Seal around the shower screen with silicon and the waste pipe and you should be good to go. You may have to apply a patch over the crack to give it some strength first. Stewie I have seen poly marble shower bases last in excess of 30 years 1 4502 I've filled, levelled and compacted around 100mm of roadbase in preparation to lay some outdoor court tiles. Prior to doing the final compaction, I dusted the top with… 0 3041 1. Roof cleaning and paint - which colour do you recommend? I often see black/ dark grey in use these days but I would prefer… 0 8313 |
