Browse Forums Bathrooms and Laundry 1 Jun 05, 2016 10:49 am I have a question. Back before the prevalence of flick mixers if you wanted to change your bathroom/kitchen taps it was (generally) a simple matter of buying new taps, removing the old handle, trims, maybe replacing the spindle, fit new and job done. Worst possible issue could be mismatched tile cuts around the trims. Now days it seems as if mixer taps are the way to go. So my question if you wanted to down the track, change/modernise mixer taps is the hardware in the wall common enough to allow this to happen easily? Clearly not talking about special mixers that have spouts and the like built in, just plain mixers like the one below. Eg provided the same cartridge sized was used could you unscrew this, remove the mixer cartridge, fit new cartridge and tap hardware. http://www.stylus.com.au/products/mixer ... ower-mixer Re: Changing modern mixer taps 2Jun 07, 2016 2:14 pm The pipe work is same but similar just need access to it and also if you are going to install never ever say again never ever use kinco nut an olive connections ever inside a wall.its illegal plumbing code Bathroom renovation will likely include a back-to-corner bath and we’re considering a freestanding tap with hand-held shower such as the picture included. My hesitation… 0 24696 How much are you ahead in payments compared to where the build is at? Have you fully drawn down the loan? 5 11933 Hi All, I'm new here! I'm in a block of 4 apartments (Waverley council) and looking to change a window to a sliding door. The window faces an enclosed garden (with a… 0 5539 |
