Browse Forums Bathrooms and Laundry 1 May 30, 2016 3:05 pm We are about to commence building and my wife wants to move our toilet and vanity around. The builders seem to like it where it is. They have indicated that if they move it the way she would like it will leave only 700mm between the vanity and shower which they think is a bit tight. My wife points out this isn't much different to a door so she sees no issues. The first one is my wife's preferred layout. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is the current layout: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ So just wondering people's views? Is 700mm to narrow? Re: Gap between Vanity and Shower 2Jun 01, 2016 1:03 pm What are the dimensions of the room? A smaller wall hung basin without storage or a semi-recessed basin would give you a bit more clearance but I'm guessing you don't want to give up cupboard space. I like your wife's layout but I think 700 is a smidge tight. Our current ensuite is the similar to the your standard layout but with the basin and the shower swapped, it gives good access to the basin but the shower door does hit the toilet, certainly no room to swing a cat. Re: Gap between Vanity and Shower 3Jun 01, 2016 3:00 pm bank What are the dimensions of the room? A smaller wall hung basin without storage or a semi-recessed basin would give you a bit more clearance but I'm guessing you don't want to give up cupboard space. I like your wife's layout but I think 700 is a smidge tight. Our current ensuite is the similar to the your standard layout but with the basin and the shower swapped, it gives good access to the basin but the shower door does hit the toilet, certainly no room to swing a cat. It is 2300x1900 2 7744 Got my stairs designed like this with 250mm Gap marked below. Gap is bec of 2 steps added between two landing area… 0 4944 This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well… 13 19526 |
