Browse Forums Bathrooms and Laundry 1 May 21, 2016 5:46 pm Hi Guys, I'm building in brookwater, QLD and currently the house in the lockup stage. The other day when I checked my bathroom wall tiles, the grout gap looks too wide to me. I measured it and it was 5mm -6 mm which didn't look right. My builder confirmed wall tiles, gap is 3 mm but my supervisor called back and said, because of the type of tiles, the gap looks big and the gap is measuerd differently and the gap is in fact correct. Does this look right to you guys? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Does this look right?? 2May 21, 2016 9:38 pm Ceramic tiles?? If so they might be rounded on the edges giving the thicker grout line Re: Does this look right?? 3May 22, 2016 8:11 pm I'm also thinking they are rounded edged tiles. Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Does this look right?? 5May 22, 2016 9:16 pm I have gone from rectified edge tiles in my old house to rolled edge tiles in the current house. The grout lines are bigger than what I am use to seeing. They are probably more like yours. Building a modified Madison 39 with Clarendon Homes in Tennyson homeone link: viewtopic.php?f=31&t=79106 Blog Link: https://minandb.wordpress.com/ Re: Does this look right?? 8May 25, 2016 7:26 pm Yeah it's an illusion because the gap is 3mm and the bevel/rounded edge is 2mm (two sides = 5mm). Tiler would have used 3mm spacers. Looks neat Re: Does this look right?? 9May 26, 2016 8:31 am Rikesh Yes they are round edge tiles..i guess from what you guys are saying this is normal for round edged ones. This is quite normal for round edge tiles. Rectified tiles get a smaller gap. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com They using concrete or timber sleepers? Timber or steel uprights? Any drainage behind sleeper? 3 5828 I'm putting a new floor in my kitchen, slate flagging on a standard concrete slab. I have allowed for a bed thickness of up to 20mm to accommodate the different… 0 17536 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 9526 |
