Browse Forums Bathrooms and Laundry Re: issue with shower water temp 13May 19, 2016 7:46 am mack042 Drekko Hello Issue we have had for a while now is, you put it hot, and then overtime it goes really cold by itself then you put turn it a fraction to hot, and then its blasts out steaming hot scalding water! If the water in a shower gets scalding hot then the install is either incorrect or the tempering valve is faulty. Even if the tapware at the shower is faulty you should not get scalding water unless the tempering valve on the heater was either not installed or not working properly. Trouble is it varies during the shower - if I'm getting it right - it can be hot then cool then hot again. Agree on setting though - if it is scalding. Maybe someone's played around with the control nut. Maybe you need an "expert" ... thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 16286 If you have a floor waste, turn on your sink and put your ear down to the central floor waste and listen. If you can hear water running then they all connect there. If you… 10 12117 |
