Browse Forums Bathrooms and Laundry 1 May 10, 2016 3:24 pm Need some advice please I'm installing a frameless glass shower panel 1200 x 2000, 10mm thick Do I need to use the stabilising arm on the top corner or will the join at the wall and floor be enough? Trying to avoid using the arm for aesthetics Re: frameless shower screen stabilisation 2May 20, 2016 12:21 pm How are you fixing it to the wall? If done properly you shouldn't need the arm. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com 2 4474 Your shower screen has failed in the way it is designed to fail with tempered glass. You could replace it with laminated safety glass but make sure it has AS standards logo on it 1 11160 You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of… 1 7062 |
