Browse Forums Bathrooms and Laundry 1 May 09, 2016 2:18 pm Does anyone know the building standard about the type of flooring required in wet areas? We love a double story floor plan and it has the powder room and laundry located on the ground floor where we may potentially have floorboards. I want to avoid having joins but it seems that all wet areas are required to have tiles? Do I have any hope of not having to have tiles in these rooms? If we did have to have tiles for whatever reason, would it be "legal" to rip them up and lay floorboards afterwards? Second Time 'Round Re: Bathroom and Laundry flooring requirements 3May 30, 2016 1:36 am You mentioned in another thread that you are thinking of building with PD. If you do, then waterproofing will be your first issue given PD's alternative solution that allows them to have a water resistant finish only. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Bathroom and Laundry flooring requirements 4Jun 17, 2016 9:40 am SaveH2O You mentioned in another thread that you are thinking of building with PD. If you do, then waterproofing will be your first issue given PD's alternative solution that allows them to have a water resistant finish only. Do all wet area floors require waterproofing? Even on a concrete slab? I thought it was only the shower recesses that had to have waterproof membrane behind tiling? I also have no idea about building codes though.... Second Time 'Round Re: Bathroom and Laundry flooring requirements 5Jun 20, 2016 5:48 pm First_Timer_Ray SaveH2O You mentioned in another thread that you are thinking of building with PD. If you do, then waterproofing will be your first issue given PD's alternative solution that allows them to have a water resistant finish only. Do all wet area floors require waterproofing? Even on a concrete slab? I thought it was only the shower recesses that had to have waterproof membrane behind tiling? I also have no idea about building codes though.... When a bathroom is done properly the full shower recess and all room corners should be done. The door way will have an alumimum angle across it and that will be water proofed as well. You have to contain the water should you have a leak. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Hey all, Hoping for some inspiration for my bathroom laundry combo. The tiles are in good condition, as is the bathtub. I’ve given it a coat of white paint and added… 0 14120 This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 11252 This was on google. Development controls 2.3.1 Front setback D1 New buildings within residential areas shall adhere to a front building line, which is 5.5-6m to the… 1 3666 |
