Browse Forums Bathrooms and Laundry Re: Removing tile glue 6Aug 30, 2016 6:16 am Beetaloo If it is an old bathroom the tiles generally are small and were fixed with thin bed adhesive. If retiling with large tiles, just use a wide notched trowel over the ribs of the old adhesive (assuming they are less than 2mm high. buy phen375 http://ohdivinehealth.com/phen375-reviews/ However don't forget to install a new waterproof membrane to present day standards. changing tiles is really exhausting. we recently changed ours for about three months if i am not mistaken. we actually did what you suggested just exactly what you advised and it make the tile easily attached on the wall without any marks or stains at all. i thinkan appropriate use of adhesive is really a big thing. Sam There is a much stronger glue than liquid nails. It's called T Rex and will stick your timber to the concrete. Cheers Simeon 1 1663 6 11303 The best advice is for you to get a competent building consultant to guide you through your build 7 4716 |
