Browse Forums Bathrooms and Laundry 1 Mar 06, 2016 11:12 pm Hi, Find below photo's. Does anyone know how to make a terrazzo mixture that will look similar to the black terrazzo in the photo's? The photos are from an existing terrazzo floor that we would like to extend. The terrazzo itself is a 10mm layer that is applied on top of a concrete slab. Thanks. http://postimg.org/image/nr86ptmbp/ http://postimg.org/image/q9tvqi81x/ http://postimg.org/image/5e7lf9but/ Re: Terrazzo floor 2Mar 07, 2016 9:52 am I know a lot of the modern terrazo floors are epoxy based but the older traditional way was based on portland cement, sand and marble chips - used for centuries. A quick google turns up these guys http://www.allsafeflooring.com.au/index ... &Itemid=26 Stewie Re: Terrazzo floor 3Mar 07, 2016 2:49 pm Stewie D I know a lot of the modern terrazo floors are epoxy based but the older traditional way was based on portland cement, sand and marble chips - used for centuries. A quick google turns up these guys http://www.allsafeflooring.com.au/index ... &Itemid=26 Stewie Thanks Stewie. The allsafeflooring links to an anti-slip pack, not the actual terrazzo mix? I am looking for how to create a terrazzo mix to extend an existing floor with terrazzo. I found this link http://www.doityourself.com/stry/how-to ... zzo-floors The cement I could buy in a hardware shop but the stone and marble chips mix? Any ideas? Re: Terrazzo floor 4Mar 07, 2016 4:31 pm I'm unsure. Maybe contact one of the large terrazzo tile suppliers like these guys http://www.terrazzo.net.au/ The biggest problem apart from sourcing those chips will be getting a color consistent to what you already have. I've seen some terrazzo steps replaced on a few sets of stairs and the guys haven't quite got the colour right. They tended to stick out from the rest of the stairs. Stewie CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16421 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17414 Hi We have Hybrid Spotted Gum Hp0995 from carpet call. It turned out to be very dark and rough. Is there any polish or product we can use to make it shinier ? 0 9174 |
