Browse Forums Bathrooms and Laundry Re: New tiled shower floor remains saturated 21Feb 26, 2016 12:10 pm Oh that's a brilliant idea! Thank you so much! I'm going to go and wet the spare tiles and see what happens! Spoken to the tile importer and they've said there's no film that needs to be cleaned off, but I've scrubbed the tiles every day (just with vinegar and water) in the hope that it was an easy fix, alas no difference yet if you can suggest a cleaning agent to try? I'll do it! Re: New tiled shower floor remains saturated 22Feb 26, 2016 4:54 pm This pooling of water is the result of not the gloss, but the smoothness of the tile. 2 very different things. If u have ever had an older car with solic colour paint and had it detailed with a polish, you will whitness this same pooling. The autface tension of the water is able to wrap around smaller portions of water and xling them onto a surface that is smoot. A rough surface doesnt allow this aurface tension to roll over and bold onto the substrate so the water runs off. This is ur issue here. A simple solution would be to have someone seal the shower tiles for you. All the best. No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 4922 Thank you so much. We ended going with the terrain that’s part of our brick. 2 2498 Thank you Splashers. Tomorrow I might check if I can get a few packs of 300x300 in the same tile finish. It may be good to use these could in the shower recesses. I'm not… 4 4670 |
