Browse Forums Bathrooms and Laundry 1 Feb 09, 2016 6:18 pm My new build property has tiles in bathroom and laundry. Firstly the tiles along one wall look much darker than the tiles along the other. Is it possible tiles look this different purely because they are different walls? Secondly, the edge of the tiles have been left exposed. Should they have sealant over the top & painted in the wall colour so it all blends in or is it standard practice to leave it like this? In the kitchen the grouting has run down the wall and left a brown stain on the paint!! Re: Tiling done right??? 2Feb 10, 2016 7:22 pm Do you have photos? I do believe you have to specify if you want mitred tiles, it's when the "shave" the edges of the tiles so you can place them closer together and not see the exposed edges. The just tile them normally and don't paint them or anything. If you can show pics of the possible different shading I could try help Our Easystart Build in Annie's Landing https://forum.homeone.com.au/viewtopic.php?f=31&t=81061&p=1478674#p1478674 Re: Tiling done right??? 3Feb 11, 2016 1:29 pm Could it be because of the lighting in the room? That doesn't sound very normal to me. Yes, the edge of our tiles was also left exposed (they painted the tops), it was suggested that we take a spare tile to Beaumonts to get a colour match paint and then paint it. Kitchen - that doesn't sound real great - perhaps add that to your maintenance list, get them to touch up the paint. I'm putting a new floor in my kitchen, slate flagging on a standard concrete slab. I have allowed for a bed thickness of up to 20mm to accommodate the different… 0 17539 They using concrete or timber sleepers? Timber or steel uprights? Any drainage behind sleeper? 3 5878 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10466 |
