Browse Forums Bathrooms and Laundry 1 Jan 25, 2016 5:18 pm I went to have a quick look at my new build and noticed that the bathroom sink that sits in the vanity has a very wide application of white silicone or caulking around the sink and its very very obvious. They think its fine and has to be like that but it looks ridiculous. I have no experience in this area so not sure if the builders just did a bad job or genuinely needs to be like that.. ? ? Second issue: my laundry is part of the garage in a closed off area and the floor hasnt been tiled. Shouldn't all wet areas be tiled.? Re: Caulking around bathroom sink 2Jan 26, 2016 9:29 am A photo of the silicone would really help! If the laundry is in the garage then no it doesn't have to be tiled. Totally up to you! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Have had stone benches with undermount sink (kitchen) and drop-in (laundry) and top-mounted basin (bathrooms) for coming up 13 years and not one chip/scratch of any kind.… 2 9678 You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7034 |
