Browse Forums Bathrooms and Laundry 1 Jan 24, 2016 1:04 pm We are looking to convert a laundry into a butler's pantry. Removing the laundry sink, replacing with a kitchen sink, and then putting a dishwasher next to the sink (hopefully using the taps that are already there for the washing machine). I am a complete novice when it comes to plumbing - looking for advice as to whether anyone has done this before, and for anyone with any plumbing experience, whether this would be a complex job for a plumber to do? What do you think, cost-wise? Re: Plumbing costs 2Jan 24, 2016 1:06 pm Also, has anyone had experience with getting a garage plumbed for a washing machine? If we were to go ahead with converting the laundry to a pantry then we'd likely move the washing machine and dryer into the garage, but not sure how expensive it would be to get new taps put in. Any advice would be greatly appreciated!! Re: Plumbing costs 3Jan 25, 2016 7:52 am For a plumber its an easy job! Its a bit hard to give an idea on price without actually seeing the job. You really need to contact local plumbers and get quotes! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Plumbing costs 4Jan 26, 2016 10:44 am Is there any services in the garage or not..where will the services come from. Water over the ceiling or around outside of house. Sewer under ground where does it lat now. Will the concrete need cutting up to run pipes if know access to side etc etc etc etc. Yer plumbing is easy when you are a plumber. If your not a plumber then not sure how can be easy to do In my experience roof is essential element of the building envelope and hence a common property and should be covered by owners corporation however a detailed review of… 3 6176 For anyone that comes across this issue in the future - Just did what aussieta said and found a plumber to inspect it and sign off on it. Was difficult to find someone to… 3 7056 5 3787 |
