Browse Forums Bathrooms and Laundry 1 Dec 13, 2015 10:44 am Hi. I could use some help fixing a leaking toilet. Its is a constant leak into the bowl internally. The guy at Bunnings told me it is a inlet valve problem. Though the one he sold me is different to the one I have. Here is a picture of the current one. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ It seams like the flush valve and the inlet valve are one unit.I can't see a way to separate them. Does that mean I have to replace both? Sorry I have no experience with this kind of stuff. This is the I have got to replace it with. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Will this be compatible? Appreciate any help. Thanks. Re: Fixing leaking toilet 2Dec 13, 2015 1:24 pm Hi mate What brand is the toilet cistern. What is the height of the water. Is the water over flowing into the over flow pipe or is it the seating washer thats leaking. Have a look here for more info http://ezyfixplumbing.com/toilet-float-valve/ DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9565 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4869 |
