Browse Forums Bathrooms and Laundry 1 Dec 12, 2015 12:36 pm Re: Replacing yucky toilet, gap between bowl and cistern 2Dec 12, 2015 3:29 pm Its a bit hard to tell from that photo but it looks like it may be either a slimline or a uniset cistern. It really depends how much work you're willing to do. A caroma concorde pan with a slimline or uniset cistern will likely be the easiest to install but be sure to take measurements of the cistern and also the pan setout (distance from the wall to the centre of the waste). Take these measurements along with a few photos to Tradelink or Reece plumbing and they will be able to show you a few different options. My build with FHBD viewtopic.php?f=31&t=78344 Re: Replacing yucky toilet, gap between bowl and cistern 3Dec 13, 2015 8:37 pm Hi mate Any low, mid or high mounted toilet suite will fit there but not a close couple suite as the hole where goes into the floor will be to far off the wall. When replacing make sure you replace the pan connector rubber as well while its apart Re: Replacing yucky toilet, gap between bowl and cistern 4Dec 16, 2015 6:34 pm Thanks for all your inputs. It does seem to be a slimline cistern. The link piece appears to be short/not close enough to the pan resulting to that gap which has some kind of warped plastic in it. Is there a way of replacing this set up with a close coupled one? Close coupled seem to be more aesthetically appealing. Re: Replacing yucky toilet, gap between bowl and cistern 5Dec 16, 2015 7:38 pm Measure the current set-out for the waste pipe and then have a look on the tradelink or caroma website to see if any close coupled suites are close to it. I dare say you will have to move the waste closer to the wall to suit a C/C and then re-tile... My build with FHBD viewtopic.php?f=31&t=78344 Re: Replacing yucky toilet, gap between bowl and cistern 6Dec 16, 2015 7:55 pm There is a place on ebay that sells closed couple toilets as i just put couple in for a customer of mine. There a p trap base and come with adaptor to convert pack to a s trap. A normal set out toilet like yours is set of the wall standard 180 to 240 mm centre where close couple need set off wall 140 think it was. So to install a close system will leave a gap off the wall.hope this helps abit 2 7515 Got my stairs designed like this with 250mm Gap marked below. Gap is bec of 2 steps added between two landing area… 0 4872 This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well… 13 19233 |
