Browse Forums Bathrooms and Laundry 1 Jul 17, 2008 11:00 am Our ho water tap is driving me nuts! When it is on the water screams through the pipes Doesn't happen with the cold tap though. The spindle is loose when it is on but doesn't leak water. i have pulled it all apart, changed washers, and o'rings. I just don't see how this thing can be loose? The hotter the water the more it screams. It doesn't really settle until the tap is wide open? Re: screaming tap 2Jul 19, 2008 4:10 pm We get this in our apartment. It's nothing to do with the taps at YOUR end I think. It's the pipes in the building.
Whenever we have a shower/use the taps in our own apartment, there's no pipe noise in our walls or anything. But every single other person in the building when they use their pipes, have a shower, etc, there's noises that range from a dull hum to a piercing scream in the walls. Ugh. How the hell did I become a senior member!? I know nothing! Re: screaming tap 3Jul 21, 2008 8:11 am yeah i think Grace is right, its also possible that you need to have your hotwater lines lagged, hotwater through cold copper tube may give off this effect. Re: screaming tap 4Jul 23, 2008 1:00 am Interesting. I do note that it happens in the tap or in the wall below the shower head near the tap. Not so much before the tap. It does make a weird noise as the hot water comes down the pipe though. Like blowing across a bottle sort of.
I tried adjusting the mains tap to less flow but that was no good. i tried the same on the hot water system too but that did stuff all. Re: screaming tap 5Jul 23, 2008 9:07 am another thing to try is a new tap body, find out what brand it is and get one that will suite. your plumbing merchant should be able to help there Re: screaming tap 6Jul 23, 2008 9:09 am Screaming noises are generally cavitation, occuring at changes in velocity of water, i.e. big pipe to smaller pipe, pipe to tap, you get the picture.
How old is the tap, if it's several years old then it may need to be reseated using a ream/reseating tool. In the past have you had to tighten the tap more than usual to get it to seal without dripping? If so the seat may be worn. If you have a worn seat changing tap washers won't often fix the problem and you'll just end up damaging the new washer. Although reseating may not be economical compared to a new tap. There endeth my knowledge on plumbing....! mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: screaming tap 8Jul 28, 2008 9:06 pm there's no restrictor there to the best of my knowledge.
I found out what bugger has my plumbing tools so I should get it sorted soon I hope. I now have some things to go on Re: screaming tap 9Aug 18, 2008 6:15 pm Hi Fu Manchu,
We had that problem in our bathroom shower (not ensuite). Of course, it only made a noise at the temperature/flowrate that was comfortable. I had assumed it was the tap cos it was a bit loose. However, since I swapped the showerhead over for one of the freebies from the water companies, it has stopped! Corner block, lake view, custom design Re: screaming tap 10Oct 14, 2008 10:51 pm I fixed the F%^&ing thing! WOO!
best give some feed back on this for others I hate threads that die with no answer. It was the tap body. I didn't note that it was different must have pulled it apart 4 or 5 times to no avail. Pretty new house but the previous owner had replaced only that tap body with a crap one. All the others had two o-rings and I put a third on the new tap body for good measure between the thread and the others The old body was drawing air in but not leaking water? anyway all fixed and working great. I put in a flow restrictor 9lts/min in the shower head while I was fluffing about with taps and replaced the airators with flow restrictors too. ( i may change the shower head one to a 12ltr/min flow resitrictor though. Re: screaming tap 11Oct 14, 2008 10:55 pm the seat looked like new still
I checked the shower head too. I tryed opening the rear outside tap to bleed trapped out. I swore lots so thanks everyone. you folks are awesome Grate, thank you! RexChan if thats the reason i could sleep well without thinking about additional cost. But 1st i'll need to read about NRV cleaning/replaing stuff. I… 7 31157 that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink 1 7394 7 5139 |
