Browse Forums Bathrooms and Laundry 1 Nov 23, 2015 1:41 pm I've been told the hot water system pressure valve at my new place needs replacing as it's faulty. The apartment is almost 40 years old. I don't know how old the hot water system is, but is it likely it will need the whole thing replaced, or is replacing a pressure valve not that big a deal? Re: Hot water system pressure valve 2Nov 23, 2015 7:39 pm Not a very big deal and i be betting the hotty you have wont be 40 yrs old thats for sure. If you want more info have a look at ezyfixplumbing.com has all details how to remove and replace valve there for you Re: Hot water system pressure valve 3Nov 23, 2015 7:41 pm Hi Stevie, Replacing the valve is a simple job. Take a photo of the plate attached to the valve as this will show the model and kpa rating, then take this down to tradelink or reece to get a new one for between $90 and $130 depending on model. It should really be installed by a licensed plumber however My build with FHBD viewtopic.php?f=31&t=78344 First time building 2 storey home, is under construction (in Framing stage) in NSW. I have 3 toilets and need bidet spray in… 0 17625 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 15042 For our new build in NSW we opted for a heat pump with a 315L storage tank. Early days yet as we only moved in 6 weeks ago. Haven't run out out of hot water though. Ours… 7 5017 |
