There is no cold water tap in the wall for a washing machine. Does the hose go in the laundry tub cupboard? Will I need a plumber to help connect it?
Photos:http://imgur.com/a/zJVrf
Browse Forums Bathrooms and Laundry 1 Nov 09, 2015 11:38 am There is no cold water tap in the wall for a washing machine. Does the hose go in the laundry tub cupboard? Will I need a plumber to help connect it? Photos:http://imgur.com/a/zJVrf Re: How do I connect a washing machine here? 2Nov 09, 2015 6:53 pm Hi Nubo, It looks like you have a 20mm w/m connection capped off on the bottom of the isolation valves? All you need to do is switch them off and then drill a hole into the side of the cabinet and connect the w/m hose to the hot (if desired) and the cold threaded connections My build with FHBD viewtopic.php?f=31&t=78344 Hey all Currently renovating our laundry, bought a new washing machine but have found that the drainage hose is alot shorter than the old machine (which I used to get the… 0 17522 |
