Browse Forums Bathrooms and Laundry 1 Oct 25, 2015 10:17 pm Hi All. I have a problem here. I had to replace a washer in the tap. Apparently while I was undoing the topmost part of the tap (see the 1st photo), I rotated the tap body which loosening connections underneath the sink (see the 2nd photo) and now it is leaking. It is the 2nd time it happened to me for the last year. Can you please let me know how can I prevent a tap body from rotating while undoing the topmost part of the tap. Thanks. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: How to prevent tap body from rotating while working on i 2Oct 25, 2015 11:43 pm The large diameter narrow nut that holds the body onto the basin should be nice and tight. Ensure the tap is in the on position before trying to loosen the spindle, and if it rotates like it has for you, then you will need to get some vice grips onto the underside to hold it in place and use sharp blows to turn the spindle rather than bulk leverage which makes the whole thing spin. Re: How to prevent tap body from rotating while working on i 5Oct 26, 2015 7:36 pm I found this video on youtube but unfortunately it is not too useful in my case as I have nothing to pull a box spanner on https://www.youtube.com/watch?v=TGF39ReBrj0 Re: How to prevent tap body from rotating while working on i 6Oct 26, 2015 9:17 pm I am wondering if I can use one of these tools to prevent the tap body from rotating ? http://www.ebay.com.au/itm/Silverline-A ... Sw5ZBWKlfD http://www.ebay.com.au/itm/Supatool-Eng ... SwhcJWHguJ Re: How to prevent tap body from rotating while working on i 7Oct 31, 2015 5:24 pm hi mate 1st of turn the tap on as that releases any tension on the seat and washer and once you have it off don't do it up so tight. Common fault. Some times to tighten the kinco nut up under the basin we plumbers use a tool called a basin spanner. Re: How to prevent tap body from rotating while working on i 8Apr 05, 2016 9:15 pm Please find below a link to my "Missing manual on fixing dripping taps" : https://drive.google.com/file/d/0B-by5E ... sp=sharing 0 17420 Recently I moved to a 30 year old house and found within few months there are small brown nests in the brick mortar and few small round holes in few places of brick… 0 22672 Hello everyone Please advice me how can I install mesh security window or we cab say mesh flyscreen inside while the pvc plantation shutters are already installed? Is… 0 11593 |
