Browse Forums Bathrooms and Laundry 1 Oct 24, 2015 11:51 am Hello all After ripping out everything in the old bathroom we're looking at cladding at least some of the walls in colour bond. We've done it before and it looks good, and I'm not sure my tiling skills are up to a full bathroom. For the basic look we're going for http://www.houzz.com.au/photos/2737284/ ... oom-sydney Anyway - the question is do we clad all the walls with bathroom grade gyprock and then colour bond over the top, or just put the colour bond straight on the walls? I'm thinking that the gyprock would lend some insulating qualities to the walls but I'm concerned about moisture buildup between the colour bond and gyprock. The other question would be about finishing the colour bond at floor level. Any ideas? Re: colour bond steel on bathroom walls 2Oct 25, 2015 11:56 pm what are your walls made of now? As for the flushing at the bottom, simply butt the colorbond down to the tiles and silicone along the curves. Re: colour bond steel on bathroom walls 4Oct 27, 2015 9:07 am might get condensation building up on the colourbond without the gyprock. SO yeh probably a sheet of aquacheck behind it. Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14449 Render your bathroom walls, two opinions versus the one, makes you wonder. 3 6064 You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7034 |
