Browse Forums Bathrooms and Laundry 1 Oct 29, 2006 2:42 pm Hi,
We are considering removing/renovating a cast iron bath, possibly around 20yr old. It is sitting on a concrete slab floor, and has a brick and tile surround. Two questions Even though I suspect that there is a cavity under the slab, there is no longer access to it. What I was wondering is how the waste pipe is disconnected such that the bath can be lifted out. Can it be unscrewed from the top. Would it be some form of slip seal such that it just slips out? The bath itself is in very good condition, but is a most unattractive colour. Can anyone give an opinion on bath painting, either professionally done or doing it yourself. Does it look like a painted bath, or is it hard to distinguish from a normal enamel bath. Is it hard wearing? Thanks Re: Bath Removal or Painting? 2Oct 29, 2006 6:31 pm G'day bas
and welcome to homeone ![]() Sorry i cant help you on the removal of the bath (I stick by the motto "If it aint broke dont fix it"..... or if it is broke call someone in to fix it.... this prevents me from breaking it even more) White knight has a product on the market called tub and tile it comes in two colours white and cream Link http://www.whiteknightpaints.com.au/pro ... tub-n-tile Or if you want a pink and purple poka-dot bath tub Norglass has a product called "Northane Gloss" this product comes in an ulimited range of colours but please contact Norglass for full product specifications Link http://www.norglass.com.au/cgi-bin/fron ... s&itemid=4 Hope this helps and good luck EGGENZ 2006 Re: Bath Removal or Painting? 3Aug 15, 2008 4:24 pm Hi,
I had a similar problem - our bath was pink! In fact, our whole bathroom was pink!! We needed a short term solution as we intended to replace the whole bathroom when finances allowed it. So for the meantime, I did all the suggested preparation and then painted the bath with "Tub and Tile' but have been less than impressed with the result. If you are considering keeping the bath indefinitely, then I would recommend getting a professional to do it for you. DIY is fine for a while, but after 6 months continous use, I've found that our bath, which I painted white with the above product ,has started to discolor and stain. Considering that it cost around $70 for the product I don't think this was very good value. On the other hand, I painted the rest of the tiles etc in the bathroom with White Knight tile paint and it has been great - it was just the bath which was a dismal failure. Good luck Cheryl Re: Bath Removal or Painting? 4Aug 15, 2008 5:58 pm We asked about having a bath professionally re-enamelled and they told us we would be looking at around $1000 for a cast iron bath.
We also have baths in many different shades...pink, blue and green (our house and a block of 4 flats). Very tasteful ![]() 'chelle We have a hand-over date...15/10...but I won't hold my breath! http://people-in-glass-houses.blogspot.com/ Re: Bath Removal or Painting? 5Aug 15, 2008 9:18 pm I'll tell you now as well, it will be impossible to remove the bath in one piece. I work for a bathroom reno company (but I'm building a house so I'm allowed on the forum ![]() ![]() Re: Bath Removal or Painting? 6Aug 28, 2008 2:35 pm (sorry this is my first post so bear with me:-)
we had a lovely hot pink bath - I think it was a normal enamel? bath which was tiled in. we got a company in to paint it - i think it cost around $600 and was painted an off white/beigey colour. It looked absolutely briliant afterwards and is still looking good! thanks nutty32 Re: Bath Removal or Painting? 7Aug 28, 2008 2:42 pm The in-laws had their pink bath and pedestal basin re-enamelled. Don't know how much it cost them but it looked really good. It took about 7 years of heavy use for a little bit of the new enamel to chip off the basin, but otherwise it was fine. Re: Bath Removal or Painting? 8Aug 28, 2008 4:00 pm My mum had her bath fixed by having a plastic insert installed.
Not sure how much it cost, but was done without diturbing the tiles Best Price Wardrobes Sliding door robes | Walk in robes Deco panel | Mirror | Melamine 26 to 28 Cottage lane Hackham M: 0402 927 376 http://www.bestpricewardrobes.com.au Trade welcome DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 3262 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 1804 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 3337 ![]() |
