Browse Forums Bathrooms and Laundry 1 Jul 09, 2015 1:41 pm Hello, My partner and I intend on changing some of the tap wear in our bathrooms after handover. What I need to know is - is this possible? We are wanting an overhead shower head in the ensuite and the one we have at the moment is just a 'stand in' overhead we will use until we purchase the larger one we want. Will we be able to easily change this ourselves? thanks for any help How much are you ahead in payments compared to where the build is at? Have you fully drawn down the loan? 5 11893 yes it is possible but watch for noise transmission, decouple as best you can. Maybe wider top and bottom plates with 70mm studs to allow the cabinet to be recessed fully 1 6634 You can wash over existing pavers with 10% solution of water and hydrochloric acid, then wash off. The acid will provide for required bond key with new concrete. 1 36950 |
