Browse Forums Bathrooms and Laundry 1 Mar 08, 2015 10:46 am We've just taken over a house, and there's maybe 4-5 of these yellow stains on top of our sink bench in the bathroom. http://imgur.com/HwGvOB4 We have tried Jif, as well as vinegar/bicarb and lots of elbow grease, but no luck either way. Does anyone know how we can remove? Any other product suggestion would be much appreciated. Re: How to Remove Stubborn Yellow Stain on Bathroom Benchtop 2Mar 08, 2015 1:51 pm A stonemason told me once and it worked to get hair dye stain out of ours. Use 'gumption' with a bit of water and make a thickshake style paste, cover the stain in this paste than cover the whole lot with a piece of cling wrap. Leave it for a few days than polish it out. This worked for me but we had a white stone top. Re: How to Remove Stubborn Yellow Stain on Bathroom Benchtop 3Mar 10, 2015 12:24 am What kind of material is the bench made of? Marble? laminate? Re: How to Remove Stubborn Yellow Stain on Bathroom Benchtop 6Mar 14, 2015 12:08 pm Try using magic squares I use them for all tough stains and so far I have managed to get everything off with them. Although you need to be careful as it may dull shiny surfaces if you scrub too hard. http://www.chux.com.au/the-chux-range/c ... ser-range/ My build thread: Custom build on 40 acres viewtopic.php?f=31&t=75656 Re: How to Remove Stubborn Yellow Stain on Bathroom Benchtop 7Apr 15, 2015 12:39 pm Can't be sure of the size, but it looks like it might be a rust stain from leaving a can on a damp benchtop? I have found laundry bleach effective for removing rust stains from laminate. Mix bleach and water 1:1, then wet a white towel or rag and lay it over the area to be cleaned. I would try a bit of string or cotton wool on just a tiny part of the stain first. Given that Gumption is made by Clorox it looks like it is a bleach product (how do firms in Australia get away with listing the active ingredient in a cleaning compound as 'secret'?? on their Chemical Identification sheets??) so that might indeed also work. I wouldn't rub it in since Gumption has abrasives in it. Chris On the threshold of retirement... and trying to check my assumptions at the door the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11835 Hi guys, I want to do some floor levelling before laying the planks and am considering doing it with self-levelling or yellow tongue PB board. I am wondering which one… 0 6538 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6709 |
