Browse Forums Bathrooms and Laundry 1 Feb 16, 2015 11:25 am Hi guys, Our en-suit shower, which is furthest away from the HWS and water mains, doesn’t seem have a great solid spray from the shower head. I need to actually check is there is a flow restrictor in the shower head, but if not, is there anything I can do to improve this by getting another shower head? Cheers, Robbie Re: Improving shower spray 2Feb 16, 2015 1:39 pm You're correct in thinking it is probably the showerhead although you may have low pressure as well that only a pressure test or an experienced plumber will be able to tell you by just looking at it. Do you have good pressure from your taps on the vanity ? If so then the pressure to your ensuite is probably fine and it is the showerhead at fault. I bought a watersaver showerhead a few years ago which saved a lot of water but the instant gas HWS used to cut out heating the water as the back pressure was too high. I took the shower rose apart and drilled slightly larger holes which solved the problem. Stewie Re: Improving shower spray 4Feb 19, 2015 1:46 pm The CSIRO, under Dr Jie Wu, developed a low flow shower nozzle that entrained air into each water droplet, giving the sensation of greater flow. The product is now commercialised and marketed as the Oxijet nozzle by the Felton company in NZ. http://www.felton.co.nz/?sid=2152 https://www.youtube.com/watch?v=zEY-SgYpAO4 Note that video is also in the above link. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9813 Hi All, about to commence a bathroom renovation and need some advice on subfloor works. Current subfloor is hardwood T&G floorboards on 90x45 joists, but intention is to… 0 5956 Ask yourself if the insurance company will be aware of the Reno. 4 7578 |
