Hi 33amc answers to your questions:
Is that a hobless shower? it sort of looks like it. - Yes
Does the floor tile that's on the outside run through past the screen a little bit? - Yes
Also. I have contacted the builder and they are going to inspect.
Browse Forums Bathrooms and Laundry Re: Water / dampness problem in bathroom 21Feb 02, 2015 9:14 am Hi 33amc answers to your questions: Is that a hobless shower? it sort of looks like it. - Yes Does the floor tile that's on the outside run through past the screen a little bit? - Yes Also. I have contacted the builder and they are going to inspect. Re: Water / dampness problem in bathroom 22Feb 02, 2015 9:06 pm Ok, If it is hobless the tile must stop and start each side of the screen with a waterstop angle between them. This stops water tracking under the tiles to the outside of the shower. Does the shower screen track run right across the door opening or can you see the tile line broken? Re: Water / dampness problem in bathroom 23Feb 03, 2015 7:22 am 33amc Ok, If it is hobless the tile must stop and start each side of the screen with a waterstop angle between them. This stops water tracking under the tiles to the outside of the shower. Does the shower screen track run right across the door opening or can you see the tile line broken? I am going through a similar problem atm. Admittedly the issues was made worse by having a long stainless grate, where instead of having silicon around it I had grout which worked it way loose. I have since come up with the same conclusion as you and wounder why this isn't. Now I am doing a lot of retro fitting and looking at products like shower plug etc. fingers crossed this solve the issue. Might have to invest in a moisture tester to determine where the moisture is going. 2 5860 |
