Browse Forums Bathrooms and Laundry Re: Floor wastes - your opinions please 5Jan 24, 2015 10:56 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Floor wastes - your opinions please 9Jan 25, 2015 1:32 am Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=70984 Re: Floor wastes - your opinions please 20Mar 13, 2015 12:23 pm Hi purrfection... How did you end up going with this? CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16652 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17593 The requirement is for a waterstop to be installed to the entries of the room, (a small aluminum 'L' angle to retain the water to within the room) can't see if they have… 1 2041 |
