Browse Forums Bathrooms and Laundry Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15924 Render your bathroom walls, two opinions versus the one, makes you wonder. 3 6065 Hi Geoff Install Puddle Flange prior to any screed. Puddle flange needs to be flush with the surface so you may need to grind away the surface to achieve this. Also as… 2 8372 |
