Browse Forums Bathrooms and Laundry 1 Oct 19, 2006 3:03 pm I need to remove some old tiles from a concrete floor, is there a simpler and faster method than hammer and chisel. I have done this before but just wondering if there is a better way. Thought about using a jack hammer but that seams a bit drastic. Re: Removal of old tiles. 2Oct 19, 2006 8:16 pm As far as I know, it is a hammer and chisel for you. SORRY.
And yes a Jack Hammer is a bit drastic! Imagine the damage you could do to the sub flooring. I don’t think there is a way to lift the concrete off the floor than the obvious. Hard work. But good exercise! ![]() Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Removal of old tiles. 3Oct 19, 2006 10:48 pm Hi Michelle.
Dabbler, many years ago I gave a mate a hand to remove tiles in a pool. We got a length of steel pipe around 5 foot long (that's how long ago it was) & welded a 6inch bolster to the end. Worked a charm once you got a start under the tiles. Possibly take less effort with a small Kanga though. Good luck & watch the eyes! Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Removal of old tiles. 4Oct 19, 2006 11:01 pm An electric jackhammer is a little more 'mild' and will take all the effort out. Damaging the concrete floor isn't too much of a worry - its easily fixed. DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 3308 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 1854 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 3407 ![]() |
