Browse Forums Bathrooms and Laundry Re: 2 shower heads in main bathroom and ensuite? 2Oct 03, 2014 7:13 pm I often wonder how often if at all people regulary use both shower heads at the same time, i.e. two having a shower together. No doubt it is 'trendy', but why spend money on something you may never use as intended ? Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: 2 shower heads in main bathroom and ensuite? 3Oct 03, 2014 7:32 pm I have a rain shower overhead and a hand shower on a rail. It will get used lots. Slightly diff to op. I would not have that set up. Re: 2 shower heads in main bathroom and ensuite? 4Oct 03, 2014 7:35 pm AussieMark I have a rain shower overhead and a hand shower on a rail. It will get used lots. Slightly diff to op. I would not have that set up. Yes, definately different to the OP, and something that I did think about for my new build. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: 2 shower heads in main bathroom and ensuite? 5Oct 04, 2014 6:56 am That is exactly the setup we are intending for our bathrooms. The handshower on a rail is very handy if you have kids and is also very useful when you clean the shower recess. Been there, done that already in our existing bathroom. Two showerheads look trendy a la The Block but for most people I think it would be very much under-used. Stewie Re: 2 shower heads in main bathroom and ensuite? 6Oct 04, 2014 7:14 am We are putting double shower heads in ensuite at either end of the shower. We will use it a couple times a week going by how often we used a single shower together. Instead of the over hear monsoon style head in the middle we are using these ones on rails with over head and removable sprayer http://www.reece.com.au/bathrooms/produ ... er-9502275 Re: 2 shower heads in main bathroom and ensuite? 7Oct 05, 2014 9:16 am how does the water pressure go with having two showers going? in every house I have had if hubby is in the shower and I turn on the kitchen tap, dish washer, washing machine or flush the toilet it affects his shower water. what affects do you get when having two showers on? Re: 2 shower heads in main bathroom and ensuite? 8Oct 05, 2014 9:32 am 2-cupcakes-pls how does the water pressure go with having two showers going? in every house I have had if hubby is in the shower and I turn on the kitchen tap, dish washer, washing machine or flush the toilet it affects his shower water. what affects do you get when having two showers on? Provided the house pipes hydraulic calculations have been correctly done, there won't be a problem. If the calculations have not been correctly done, you will have pressure problems and this almost certainly would also apply to other fixtures as well. This would be a symptom of having a bad plumber, not two showers. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11835 4 10822 The warning is on the sticker on the door too. Second the aluminium powdercoat 6 18200 |
